ScottG wrote:
JumboJet wrote:
I have a friend that had smoke and fire damage on the outside of his 5th wheel RV from his water heater. The large paper wasp nest caught on fire when his water heater ignited.
I don't think that was a problem for Atwood.
Was the Norcold refer problem some external debris that should have been cleaned before using?
The original recall issue was tubes cracking which would spew flammable liquid onto the burner area.
Please identify the flammable liquid that was spewing.
These fridges are filled with aqueous ammonia and then capped with a hydrogen cap creating an inert atmosphere in the cooling unit to prevent corrosion. Hydrogen being the gas of choice as it is the best gas for cooling.
