goufgators
Sep 25, 2013Explorer
Norcold fires...
I've read a great deal about Norcold fires. And, maybe I just missed it but was wondering... when the fires ocurred, were the units working on gas or electricity? Thanks for your responses. / Larry
moisheh wrote:
Doug: Normally I would bow to your years of experience and technical knowledge. However reading posts and looking at pictures from those who caught fires before they burnt the whole thing down many of them were right around the element area and the units were on AC. There have also been posts from those who inspected that area and found charred insulation. They tested the elements and something was amiss. I would guess that there are many causes of the fires other than the elements. The recall seems to cause even more problems. I have read where an owner did the recall and the fridge died. Upon inspection the tubing had leaks exactly where the sensor was attached. Then there are problems with the black box failing and the unit shuts off. Of course this and other forums are not a reflection of the whole market for RV fridges. We do not see many posts about the Dometic 4 doors as most mfrs. have been using the Norcold. But Dometic has a history of bad boards going back at least 10 years. The Norcold really is a bad design. How can anyone produce a fridge where if the door gasket goes you must replace the doors at about $1000. There are more and more Class A,s that come with factory house fridges.
Moisheh
