dougrainer
Mar 04, 2015Nomad
pianotuna wrote:
Hi two,
The Fridge boiler works best at 130 F. That's why the cooling thermostat is set where it is.
This unit is even better than the simple thermostat:
ARP over temperature protection
The cooling fan tstat has nothing to do with the boiler flue temp. The tstat is ON the condenser fins and THAT temp is what activates the fans. In most conditions above 70 degrees ambient the fan tstst will go over that 130 degrees on the condensor fins. The NORMAL operating temp of the burner area flue is 350 degrees. Doug
38,773 PostsLatest Activity: Apr 24, 2026
