Ivylog
Mar 04, 2015Explorer III
pianotuna wrote:
Hi two,
The Fridge boiler works best at 130 F. That's why the cooling thermostat is set where it is.
This unit is even better than the simple thermostat:
ARP over temperature protection
Adding to this:
The external fan you are looking at is set properly assuming you mount the Tstat on one of the bottom coils. OP, a link to it would be helpful. $80 is fairly expensive for a $10 fan and a $15 T-stat but finding that T-stat could be hard. This one comes close.
The ARP control is a better shut down device than the simple recall box that NoCold has put on as a bandaid. You can learn a lot by reading the info on the link to ARP and yes I've put one on my 1200.
38,773 PostsLatest Activity: Apr 24, 2026
