vegasfoodguy
Mar 04, 2015Explorer II
Ivylog wrote:pianotuna wrote:
Hi two,
The Fridge boiler works best at 130 F. That's why the cooling thermostat is set where it is.
This unit is even better than the simple thermostat:
ARP over temperature protection
Adding to this:
The external fan you are looking at is set properly assuming you mount the Tstat on one of the bottom coils. OP, a link to it would be helpful. $80 is fairly expensive for a $10 fan and a $15 T-stat but finding that T-stat could be hard. This one comes close.
The ARP control is a better shut down device than the simple recall box that NoCold has put on as a bandaid. You can learn a lot by reading the info on the link to ARP and yes I've put one on my 1200.
X2 There is also an optional ARP fan kit, if the refrigerator is in a slide out
38,773 PostsLatest Activity: Apr 24, 2026
