Jerseydevil
Aug 10, 2019Explorer II
opnspaces wrote:
Does it cool better on gas? What is the model number? I believe you can find the model on a sticker inside the door. If you remove the outside panel can you see yellow powder? With the outside panel open can you carefully touch the chimney area and see if it's getting hot?
N611. Gas no better.
Panel was removed. Made sure no wires were off. Did not see any powder. Tubes and evaporator felt warm.
