dougrainer
Aug 12, 2019Nomad
pnichols wrote:bobndot wrote:pnichols wrote:Mfan wrote:
It might be an easy fix. Is it on? Unplug the thermistor. That will call for max cold. If it gets cold, there is your problem.
Just curious for future reference, as we have the same model in our 2005 RV ... where is the thermistor and what does it look like?
Thanks in advance!
The 2nd pic is a 611 with location and wiring detail.
https://www.arprv.com/norcold-thermistor.php
Thanks ... that's what and where I thought it was.
I've read in the forums about sliding the thermistor up and down on the cooling fin in order to slightly adjust interior refrigerator temperature independent of the main (freezer) temperature setting.
Sliding the Thermister up and down is just for AUTO TEMP refers. They have no adjustable tstat. Moving the Thermister on a Auto temp only changes the interior temp about 4 to 6 degrees max----ie- was at 38 degrees and you move it and now at 34 degrees. Will NOT be a factor for poor cooling or NO cooling. Doug
38,782 PostsLatest Activity: Sep 10, 2026
