dougrainer
Aug 12, 2019Nomad
Jerseydevil wrote:joelc wrote:
? Is it iced up. Does it need defrosting. Where are you and what are the outside temps. What Temperature are you trying to keep it at. I have my Norcold on No. 6.
A muffin fan will work wonders if placed blowing over the evaporator coils outside.
0lder unit 2006. Have stat in middle. Has power, no ice up,light is green,in NJ, about 80 out.
Odd, and freezer has layer of ice at bottom.
A BAD/Blocked cooling unit will still freeze water in the freezer. Odds are, you have run it out of level enough over 13 years that the accumulation of doing that has finally blocked the refer. The ONLY sure way to verify is to wire the 120 element direct for 24 hours and see what happens. If it does NOT get down below 40 degrees the Cooling unit is BAD and needs replaced. Also, is the Refer in a slide room? Have you checked to roof top ventilation to make sure it is open for hot air to flow out? Doug
38,782 PostsLatest Activity: Sep 10, 2026
