Dachristianman wrote:
I just did this job on mine. I bought a new Amish cooling unit for somewhere around $750 and installed it myself. Not a bad job once I got the fridge out. Someone had used some black goopy stuff on the bottom of my fridge and that made it a pain to get out. Otherwise I had the cooling unit swapped out in about 2 hours.
My RV is a 92 but I opted for the new cooling unit despite the warnings about the old electronics, etc. A residential is an option, but I don't think they're designed for the shaking that it'll put up with. Besides, you can't run a residential on gas, but then again with the solar unit, you might not need to.
Good luck and let us know which way you go.
Tom
Ok but was it a 1200 series? I exspect not
