Gjac
Aug 10, 2014Explorer III
Does the freezer get cold but the refrigerator part stay warm? How long do you keep it on before you check to see if it is cool. They way I tested mine was to plug the 120v heater element directly into a 120 volt circuit this will bypass the control board and eliminate any other electrical problems. The element has 2 wires attached to it you should wait 24 hrs to see if it cools. If it does your cooling unit works and the problem is in the electrical side.
