dougrainer
May 11, 2016Nomad
lj2654 wrote:
I went to turn on my frig yesterday and no power. Checked the area behind frig at access panel and found the "Revision E" black box has red light on again.
I had the cooling unit replaced 4 years ago, and its been fine since, except for having the black box replaced twice under Norcold warranty. A sensor was replaced once also.
It will reset but trips soon after. frig is fine with black box bypassed. same as every other time. Is Norcold still replacing these boxes free of charge?
If the refer checks out fine Norcold will replace the Recall kit. Note that ALL parts are supposed to be replaced, not just the black box. BOTH the sensor and the Black box as a kit is replaced. Doug
