al_hillman's avatar
al_hillman
norcold refrigerator does not power on
my norcold refrigerator model1200LRIM says no ac.was working and had it parked outside.Noticed the roof vent cover was missing and it had been through a couple of rain storms.Never noticed any moisture inside but it just quit working.I do not have any propane in the unit so I rely on electric power only.The code on the panel just keeps flashing no ac and will not power up to cool. any ideas?Has power because the inside light comes on when door is opened an panel searches as normal.
  • Thanks for the help. Found out gfci had tripped and had to replace it. All is well.
  • Had same last week. Checked the two fuses both were good. Could smell the burned board. Removed board. Large burn area. New Dinosaur board from Amazon. Now cools better (don't know why) and holds temp ranger tighter. My codes were No Ac No Fl. Good luck
  • Start be resetting all the circuit breakers in the 120 volt panel. Turn off all breakers applying light pressure toward off. Turn on main breaker if equipped. Turn on branch breakers one at a time.
    Next test receptacle in the refer outside access with a known good appliance. Drill, light or similar.
    Test the 120 volt fuse on circuit board.
    Next test the output from the circuit board for the 120 volt elements.
  • If you do a search for 1200LRIM Manual it comes up on page 13. There are a few things you can check out there.
    Your light and power board will be working off the 12 volt battery power.
