Ivylog
Mar 15, 2015Explorer III
BigD is trying to recommend this unit which is half the price BUT it's not going to cool any better than your current unit. If you are happy with how your's has cooled then I would consider one. If you compare the size of the bottom coils on your unit (and the above) to the pictures of the Amish ones below you will see why the Amish cool better.
Dforce is probably the largest re seller of Amish cooling units... even one charged with helium.
I had Leon change mine out five years ago when I was in IN and while it's better than the NoCold I would not call it great. I recently bought a Whirlpool Model: WRT771RWYW 21 cu ft that should fit with only a minor change to the top of the cabinet but have not installed it yet.
Someone who went residential recently posted that he was going to miss his 1200 and:
worrying about it catching on fire
carrying a spare control board, ignitior, directions for resetting the board when it locks out
soft ice cream especially when letting it make ice
turning the extra fans on when it's hot out
bypassing the NoCold recall box when it shuts off the power for no reason
checking the ARP readout when the fin temp readout is above 32 to make sure it's still working
moving the fan on the fins to different locations to defrost the ice
turning the unit off ever other day to stop the four hour defrost cycle from raising the inside temp by 10 degrees
not putting hot items in until they have cooled off
I think I've just decided to give it up on my 1200 as I already have enough solar and batteries. A 1000W pure sine wave inverter and pulling the driver's side window plus a couple strong backs......
