snowbird47 wrote:
We have a Norcold 4 door refrigerator, model no. 120x-IMXX in our 2004 MountainAire. It was working fine when we shut it off last fall, now it won't come on. The fuse is fine and there is power at the plug. Any suggestions? Is there a fuse somewhere in the fridge? The groundfault is fine in both the kitchen and bathroom. We had a recall on it a couple years ago and had it taken care of. Thanks for any suggestions....
Having 120 power has no effect on a RV refer coming ON
It takes 12 volt power. Since you have a 1200 and have had the recall done, you should see the recall box mounted above the Circuit board on the bottom cooling coil. IF the RED LED is ON, the recall box has tripped and allows no power to the refer. Have you checked for 12 volt power to the refer? The recall boxes can sometimes trip from long time storage with no power. And also, a quick 12 volt power surge when dormant from a long time. Doug
