Ivylog wrote:
Since it's stopped working while not on, it's easy enough to bypass the recall box as it only has four wires. The two small ones go to the sensor in the flue to detect an overheat and a 12V in wire and a blue 12V out wire going to the control box. Put the 12V in to where the blue wire goes and see if you have power to the indicator and that the light comes on when you open the door.
CAUTION! CAUTION! You CAN bypass the recall box to TEST ONLY...I would not operate the fridge WITHOUT the protection of the recall box.
You have TWO fuses INSIDE the black box you'll find just forward of the recall box. One is for 120VAC and the other is for 12VDC. Use a meter to check them for continuity. My guess is one of them is blown.....easy fix, just make sure you replace them with identical fuses......Dennis
