- goldenhawk9ExplorerIt's a Norcold Model 1200LRIM.
- Old-BiscuitExplorer III
mccsix wrote:
That unfortunately is also the normal characteristic of a dying Norcold.
Not when it is cooling correctly on AC - mccsixExplorerThat unfortunately is also the normal characteristic of a dying Norcold.
- Old-BiscuitExplorer IIIWhat Norcold Model is it?
- goldenhawk9ExplorerWhat is the best source for parts breakdown and access to clean out flue?
- Old-BiscuitExplorer IIIRefrigerator is NOT cooling sufficiently on LP.
Freezer getting down to 15F is NOT cooling enough therefore food section can't begin to cool down sufficiently.
Not enough 'heat' transfer occurring on LP.
As stated
Low LP pressure
Dirty burner
But most likely dirty/sooted up flue/flue baffle
Flue baffle is key to proper heat trasfer - JimM68ExplorerFreezer ok, fridge not is the first sign of a problem, or worse a failing cooling unit.
Your freezer should get down to 1 or 2 degrees. The fridge should follow at 34-36... - wolfe10ExplorerThe freezer unit gets the "cooling" first. If inadequate, there is not enough left to absorb the heat in the refrigerator.
Many factors can limit cooling-- these are some of those related to the LP heat source:
Low propane pressure (regulator may need adjustment or replacement
Dirt in refrigerator gas jet
Dirt, rust or insect nest in burner tube
Basically, start by doing a COMPLETE burner area tune-up, not a short cut "blow it out" one.
Check propane pressure to insure it is 11" WC.
38,712 PostsLatest Activity: Apr 06, 2025
