ncrowley's avatar
ncrowley
Explorer II
Mar 23, 2014
"Normal" Oil Usage
I have a Cat C7. How much oil should it use in a year? Should I never add oil between the yearly changes or is it normal to add oil? When should I worry?
I just had to add 2 quarts - the last oil change was June 2013. I have never had to add oil before.
  • I have put about 4K on it since the last oil change. The oil was just at the add line and I filled it until it was at the full line.
  • How many miles since your last oil change. You mention a date, but not how many miles you have driven.
    By far, the #1 cause of oil "consumption" is overfilling the crankcase.
    Your chassis maker, not engine maker fit the dipstick. Do not assume it is necessarily accurate. It would not hurt to CALIBRATE IT-- free at your next oil change.
    Also, have you confirmed the correct oil quantity with Caterpillar-- give them a call with your engine serial number: 877 777-3126.
    Lastly, with any diesel engine, do not add oil until the oil level gets to the ADD mark (yes, on a calibrated dip stick).
    I know this sounds complicated, but with engine maker doing some things and chassis maker doing others (like the oil dip stick) that is how it is.
  • I had my C7 for six years. Normally put about 5K/yr on it and changed the oil every winterization. Not once did I ever put more oil in it during the year.
    Ron
