Winnipeg wrote:
First, Tiffin is putting 2 @ 6V batteries into the Alegro 32SA. That is better than 12V (I think). Second, the residential fridge is OPTIONAL on this model. So, I can get it with the good old propane/12V fridge.
Thank you for the on-topic comments
Uh, the two six volt batteries ARE one 12 volt battery (Eqaual to a 4D in case you wonder)... This has gotten me in lots of arguments.
When in your hand going to or from the battery store, Or in my case on the Store Assistant's hand cart, they are indeed two six volts.
but the moment you hook up that jumper between the 1st and the 2nd they magically become one big 12 volt battery.. I say this because many times I have seen questions about how you tread them different from a 12 volt.. The answer is you don't
Can I replace just one: Can you replace half a 12 volt battery
Do they have to be teh same (age, size, make, et-al) can you get a 12 volt battery that is say half interstate/half Excide?
How do I charge THEM (you charge IT the single 12 volt, Just like a pair of say Group 29s)
Makes life so easier to think of the pair as a single battery, for they are just that when properly installed.
