RVWithTito
Dec 02, 2014Explorer
There are a lot of factors to consider as the responses suggest.
If you're considering solar (which I recommend you do in your situation) this may help answer some questions and get you started.
Common Questions/Answers About RV Solar
Like you I started out with a single house battery with no room for a second. I had to convert an existing storage compartment into a battery bay and did some rewiring. I'm running 2 - 6 volts with 250 watts of solar.
Good luck!
Good luck!
