time2roll
Dec 02, 2014Nomad
Johnny Dearborn wrote:Usually batteries should be in the same compartment. You probably have a storage compartment that can be used to add two even four batteries close to each other.
I took my rig into my local shop. We're going to toss the existing 12v battery and put in two 6v AGM batteries. No custom fabrication necessary. One will go in the existing compartment. The other will go inside the coach. I'm going to look into solar as well. Any suggestions on solar systems for a smaller RV?
You definitely want solar. I think you want 200+ watts in some form on the roof. You are just a short trip from a great seller in Norco. www.solarblvd.com
Here are some solar threads to look at:
Forum Members Solar Installations With Pics
