FIRE_UP
Sep 20, 2018Explorer
Bruce Brown wrote:
On the welds, be sure to cut them with a cutoff wheel or grind them off, don't take a torch to them.
I see you're in Syracuse. Feel free to PM me if you need any help removing it. I'm in Syracuse on a somewhat regular basis.
Well,
That's fine IF, you have the clearance at all angles to manipulate a cut-off wheel and motor. There's nothing wrong with using a torch, IF you know what you're doing. Of course the cut would be cleaner with a cut-off wheel.
This SPECIFICALLY why I advise to install any M/C lift by BOLTING it on. That way, there's no need for any CUTTING when it comes time to remove it. And, it's just as strong. Oh well, I'm sure the OP will deal with it.
Scott
38,766 PostsLatest Activity: Jan 10, 2026
