- rgatijnet1Explorer III
Gdlow wrote:
rgatijnet1 wrote:
Think I found it..but have to loosen the dash to be able to use my OBD ll.
Under the dash, left of steering column.
You shouldn't have to loosen anything. Just align things up and it should just slide in. - GdlowExplorer
Under the dash, left of steering column. - GdlowExplorer
MountainAir05 wrote:
it is the workhorse chassis.
If Ford, then should be above your RH leg up under the dash or attach to steering shaft or there about. If never used probable still tape in the wiring harness . Its there use a good light. - rgatijnet1Explorer IIIUnder the dash, left of steering column.
- MountainAir05Explorer IIIf Ford, then should be above your RH leg up under the dash or attach to steering shaft or there about. If never used probable still tape in the wiring harness . Its there use a good light.
38,705 PostsLatest Activity: Jan 26, 2025
