Gdlow's avatar
Gdlow
Obd ll port on 04/05 workhorse chassis
Anyone know the location on my 5342 2005 Dolphin for the OBD ll port or how to spot it..?
Thanks
  • Gdlow wrote:
    rgatijnet1 wrote:
    Under the dash, left of steering column.
    Think I found it..but have to loosen the dash to be able to use my OBD ll.
    You shouldn't have to loosen anything. Just align things up and it should just slide in.
  • MountainAir05 wrote:
    If Ford, then should be above your RH leg up under the dash or attach to steering shaft or there about. If never used probable still tape in the wiring harness . Its there use a good light.
    it is the workhorse chassis.
  • If Ford, then should be above your RH leg up under the dash or attach to steering shaft or there about. If never used probable still tape in the wiring harness . Its there use a good light.
