- 1492ModeratorMoved from Forum Technical Support
- Drterry904ExplorerUPDATE ON COACHMEN OBD PORT LOCATION. I Read some of your post that sent me in the correct direction. Coachmen had the port "with cap" up loose in wiring right side if steering post. I pulled it down and tie-wrapped it is a easy to reach location. Thank you all for your help!!
- pconroy328ExplorerBy regulation it has to be within 'X' inches of the steering column. On all of my cars, they're within 2" of the column and attached to the bottom of the dash.
Easy to see once you know what you're looking for. But they're also usually black ports on a black dashboard! :) - jhladyExplorerMine is attached to the steering column at the bottom. Had a rubber cover over it that says ODB II. My Mirada is a 2014 however, but I don't think they are that different.
Good luck! You will love the 5 Star Tune! - ADAD437Explorershould be under the dash just above the steering column, hid.
38,761 PostsLatest Activity: Nov 16, 2025
