Mich_F
Jul 05, 2014Explorer
TravellingTrader wrote:
Does the OCCC (in this case 2187) assume full tanks or empty?
If the OCCC is 2187 and the GVWR is 11,500 does that mean this MH weighs 9313 pounds?
Then, the GCWR shows 13,000/18,500. Why two numbers and what are they telling me?
Thanks in advance. I really appreciate this forum helping me make an informed choice.
TT
I believe the OCCC assumes full fuel and propane, but no water.
That motor home should weigh 9313# with full fuel,propane and no water.
I'll assume lawrosa is correct with the GCWR numbers depending on which engine is chosen - the 5.4L or 6.8L.
They are telling you the maximum weight your motor home, fully loaded, with passengers, and what ever is being towed is rated for.
38,769 PostsLatest Activity: Mar 29, 2026
