DonSmith
Jul 26, 2017Explorer
Update on my problem, not solved, unfortunately. I was convinced my remote sensor was bad so I changed it out. I noticed that the temperature reading on the thermostat stayed at 99 degrees even though it was much cooler. So after that I decided that the problem is at the thermostat, so today I received a new one. The problem remains. The item on the new stat is 99 degrees. If I disconnect the remote it just goes blank. I wonder if anyone knows if a short in the sensor line might cause it to read the max temp, 99 degrees? From what jyrostng said it might be that with no resistance in the line it might either read the max or the min?
38,782 PostsLatest Activity: Sep 10, 2026
