msmith1199 wrote:
Mine did the same thing. Actually it has reset two different times now. I took it to Freightliner and they basically said it happens and there is nothing they can do about it. On mine they weren't even able to hook in to tell me what the real miles were. How were you able to read the ECM miles on yours?
When I called the Freightliner hotline after mine reset, he talked me through the menu screens on the "Information Center". From the Home screen you select "Service". This is, at least on mine, for "Authorized Service use only" and you must enter a password. He gave me the password, which I don't think I should provide on a public forum. (It may not even be the same for yours.) I would think if you explained the problem to them, they would help you obtain the ECM value so you can determine the amount of error in the display. I'm not sure that all Freightliner service employees are aware of this procedure. As I remember, he seemed to have to do a little research as he talked me through it. Good luck.
