Usmcsousa
Mar 30, 2014Explorer
RogerComm wrote:
I jus replaced mine after the southeastern ice storm. A pine limb fell on the roof and cracked the outer dome. Mine was quite a bit larger though, a neo-angle with 32" sides. The inner was ok but it was kind of hard to get the two pieces apart since they were stuck together with butyl tape. The manufacturers usual use the skylight to allow for more headroom so that is why they are domed. If you don't need the extra headroom, then don't see why you couldn't try a flat piece of plastic, just get something that is highly UV resistant.
definitely no issue with head room, for the "bubble" to even work for added head room, my face would be in a box in the ceiling, which would NOT work for showering lol. I'll check eBay, but if not I may just go get some UV pelxi or even do an inner and outer thing-a-magig with my inner plexi tinted and outer flanged and flush to the roof.
38,783 PostsLatest Activity: Sep 10, 2026
