Dewclaw's avatar
Dewclaw
Explorer II
Oct 31, 2020
NL Skylight lug broke off
So, I found a piece of semi-circular white plastic laying on the bed. Looking around in the bunk area I found that one of the plastic lugs that the skylight latches to had broken off the frame. Luckily I always rope the darned thing down when we are on the road so it held with just one side latched.
Now the problem is how to fix it. It's part of the internal skylight frame and I can't see buying an entire frame. I'm thinking that I will make something that will have a lug that the latch can hook onto and which will fasten to the plastic frame.
Have any of you had a skylight failure like that? If so, what did you do to repair it? TIA
