Usmcsousa's avatar
Usmcsousa
Of course I broke it... skylight
Well whilst removing my shower surround to replace with a nice new white one, I threw the corner of the shower plastic up and through the bubble skylight..
now As you may have guessed, its time to replace it.
Couple of questions, firstly Im seeing two pieces to these things online, as far as I can tell I only had an outer plastic dome piece. What is this inner piece and do I need it? I have a decorative framed box on the inside .
secondly and more importantly to my wallet... Are these things really $100+ for each piece, inner and outer(if needed)
I mean its a flimsy bubble of plastic dome at 14x22inches.. I'm tempted to just get a clear thick section of Plexiglas which would be far more durable. And machine it on a table router to make my flange and gasket/ seal it as I would a dome piece..
any suggestions? Or maybe I'm looking in the wrong places and I can actually pay a good price for an imported thin piece of plastic rubbish..
thanks in advance folks.
  • If you plan on making it yourself, use Lexan instead of Plexiglas. Lexan can be machined, bent in a metal brake, drilled, and will not break if hit with an object.
    The use of two pieces was probably to act as a thermo barrier to prevent the shower from getting too hot in the Summer and too cold in the Winter.
  • mobilefleet wrote:
    paiod $65 for mine on ebay and that was both pieces. same size as OP
    thanks for the tip, just ordered a clear one for $35 including shipping.
  • Not sure why the builders use double. Usually the top is clear and the inner is frosted for modesty. At a minimum I would replace the top and if you want privacy sand it with 600 grit of so. Even better would be a heavy tin to reduce the heat load. The hard part is building out the lower half to cover the area between the ceiling and roof. Shouldn't be very hard since you know what a router is.
  • Executive wrote:
    I'm left wondering WHY you would do that....:h....:W..Dennis
    must have doubled up on my vitamins M,A+N this morning.
    spent the good part of an hour with some choice words directed at myself, and wondering why exactly I did that.
    happens a lot im afraid.
  • I just replaced my shower skylight. The original was a double domed skylight. The two domes were sealed together. When I got the new one it was in two pieces. The outer dome and the inner dome that was mounted on the inside. Un fortunately the inner dome had the wrong dimensions. The outer dome fit perfectly. So I now have a single dome skylight in the shower.
  • RogerComm wrote:
    I jus replaced mine after the southeastern ice storm. A pine limb fell on the roof and cracked the outer dome. Mine was quite a bit larger though, a neo-angle with 32" sides. The inner was ok but it was kind of hard to get the two pieces apart since they were stuck together with butyl tape. The manufacturers usual use the skylight to allow for more headroom so that is why they are domed. If you don't need the extra headroom, then don't see why you couldn't try a flat piece of plastic, just get something that is highly UV resistant.
    definitely no issue with head room, for the "bubble" to even work for added head room, my face would be in a box in the ceiling, which would NOT work for showering lol. I'll check eBay, but if not I may just go get some UV pelxi or even do an inner and outer thing-a-magig with my inner plexi tinted and outer flanged and flush to the roof.
  • paiod $65 for mine on ebay and that was both pieces. same size as OP
  • I jus replaced mine after the southeastern ice storm. A pine limb fell on the roof and cracked the outer dome. Mine was quite a bit larger though, a neo-angle with 32" sides. The inner was ok but it was kind of hard to get the two pieces apart since they were stuck together with butyl tape. The manufacturers usual use the skylight to allow for more headroom so that is why they are domed. If you don't need the extra headroom, then don't see why you couldn't try a flat piece of plastic, just get something that is highly UV resistant.
