Dale_Traveling
Mar 30, 2014Explorer II
Not sure why the builders use double. Usually the top is clear and the inner is frosted for modesty. At a minimum I would replace the top and if you want privacy sand it with 600 grit of so. Even better would be a heavy tin to reduce the heat load. The hard part is building out the lower half to cover the area between the ceiling and roof. Shouldn't be very hard since you know what a router is.
38,783 PostsLatest Activity: Sep 10, 2026
