rgatijnet1
Mar 31, 2014Explorer III
If you plan on making it yourself, use Lexan instead of Plexiglas. Lexan can be machined, bent in a metal brake, drilled, and will not break if hit with an object.
The use of two pieces was probably to act as a thermo barrier to prevent the shower from getting too hot in the Summer and too cold in the Winter.
38,783 PostsLatest Activity: Sep 10, 2026
