wny_pat1
Mar 16, 2012Explorer II
Jim@HiTek wrote:JcoFS3500 wrote:
A tow with a wrecker may be cheaper than trailering it if the permits are an issue.
Can that be done with such a large rig? Would there have to be someone inside to steer? What about brakes when there's no engine? I'm thinking if that it would have to be a huge wrecker to tow that sucker.
They lift the steer axle right off the ground, just like a motorhome and hook the air lines to the air brake system of the bus. That way the bus brakes works off the operation of the wrecker's brakes. Not much different than hooking to a tractor trailer. Only problem is the cost per mile would be higher than a tractor with a drop frame.
38,780 PostsLatest Activity: Aug 05, 2026
