Mighty_Thor
Feb 28, 2013Explorer
Tony, thanks for the link.
The Radius Rods I am rebuilding are massive and somewhat unique. The one shown is splined half way through and matches splines on the 1 inch bolt and the attachment plate. On the other end of the rod the center piece has a tapered hole that matches the tapered pin on the bus frame. In order to use any other rods I would have to modify the attachment points on the axle and the bus. I hope to avoid that by rebuilding the original bushings with more modern materials. If they work, they should last longer than I will.
38,780 PostsLatest Activity: Aug 05, 2026
