185EZ wrote:
udidwht wrote:
185EZ wrote:
I don't see the need to have an oil analysis done unless you are having problems or maybe want to purchase a used vehicle.
To have them tell me my oil is good for another year isn't worth the time and money.
Just do an oil change.
Maybe the oil is still "good" but to keep any oil in a motor for over a year is just asking for problems.
There is still stuff in the oil that's hard on seals and gaskets.
Incorrect. If that were the case the oil analysis would have showed that. If one is worried about something in the oil that's typical of oil after haven been ran a few thousand miles what's a few thousand miles more?
Nope
Go ahead and keep your old oil in it.
You'll find out the hard way long term
All my long term vehicles have never had an oil related issue due to preventative maintenance and never wasted my money on an oil analysis.
Again incorrect. A simple search can provide a lot of info on this.
There is not a single engine that has ever had an oil related issue as a result of going 6000-7000 miles.
Never. Fact.
Changing the oil more often than necessary has consequences. Oil requires some miles to be put on it before it actually lowers wear effectively vs 100% virgin oil out of a bottle. Much the same with an oil filter. A filter filters better after haven been in the engine for 1000 miles+.
A finding of high copper alone is not an issue and quite common unless other abrasive wear metal/s such as iron, aluminum, chromium, etc. are present at higher than normal levels.
Some reasons for high copper level:
1. Oil cooler/s (GM oil leaching from cooler)
2. Radiator/s tubing
3. Leaks from radiators (no leak in mine)
4. Oil additive/s
The above instance (high copper) would also be showing other higher than average wear metals & contaminates in an analysis if there were an issue. Copper in and of itself? No. Normal.
