dougrainer
Feb 28, 2017Nomad
It took 250 miles BEFORE you had the Fault. IF overfull was the cause, do you not think that it would happen BEFORE 250 miles??????? I would make the apt at Cummins and have them check it out. They have the Code reader and will be able to determine WHAT caused the Check/fault to come on. The code is stored in the computer. This is CHEAP piece on mind, while you are still in the area. What if they find a blown/leaking seal caused by the overfull condition? Doug
38,782 PostsLatest Activity: Sep 02, 2026
