ct78barnes wrote:
Thanks for all the help I will have to make up my mind before oct 31st since I do it my self and only cost 30 dollars to change it would be cheep insurance . I have a extended service plan and I need to keep records of all the oil changes . so again thanks I will have to make up my mind. I have owned it since new and all ways changed the oil before the winter storage.
What I would worry more about then the oil is the gasoline. You need to add some Stabil, run the engine after you add it so that it gets through the small jets in the fuel system. Gasoline does have a tendency to jell up and years ago it would actually turn into a varnish in the carbuetors and plug up the jets. But even with fuel injection systems a person should add Sta-bil to the gasoline IF you are going to let it set for that long of a period.
