- 23hotrodrExplorerHello- Here are some oil filter numbers for the Workhorse chassis with the 8.1L engine--
Oil Filters
AC PF454 standard
AC PF1218 1 qt capacity
NAPA 7099 standard
NAPA 1060 1 qt capacity
Wix 57099 standard
Wix 51060 1 quart capacity
Good luck - harold1946Explorer
DaveanSonia wrote:
Hi All! This year I got a 2004 Pace Arrow and soon I'll need to change the oil @ filter but I was checking the FLEETWOOD Manual and the oil filter is a W8800470. What is that? Is there a cross reference I can use (like NAPA) were I can fined out what it means?
That is the Workhorse part number for the oil filter on an 8.1L Vortec engine. - gboppExplorerWhich engine/chassis is under your Pace Arrow?
NAPA, or any parts store, can give you the correct filter with this information. - jerseyjimExplorerFind out what motor you have. Then go to an auto parts store and look up the motor in one of their books. There are also cross-references usually in the back of these books.
For instance, my GENERAC generator...."their" oil filter costs around 8 bucks.
NAPA has the same one for 4.
g'luck! - RollnhomeExplorerStandard filter can be found at any auto supply. Either Ford V10 or Chevy 8.1.
- GGoodsellExplorerWhat is the make and size of your engine? Use that information rather than the Fleetwood number.
