Gjac wrote:
When making a long trip like Alaska I had to change the oil twice once at a CG with the MGR's permission and once at a boondocking location. Most all the other trips were less than 7000 miles so I just change oil before the trip.
I done dozens of DIY changes on the road, since we travel extensively, including four PA to AK trips, and frequent 5-8K mile trips. I do the V-10 in our Winny class A and the tow car, a CRV. I have done changes in everything from public parking lots, to abandoned commercial properties, and roadside pull offs. Nobody cares what I'm doing, while spending many hours under the motorhome and car, for oil changes and repairs. I had one interaction with a police officer. A Seward AK. officer stopped to ask if everything was OK, then had a nice conversation, and let me know that the town harbor would take my used oil and filters to recycle.
The Ford V-10 is super easy to do an oil change on. I discovered a trick to keep it all very clean with that engine. I grab a $.99 tin roasting pan from Walmart, when I pick up the oil and filter. I poke a half inch hole in the corner of the pan, then lay it across the front axle. It serves as a giant funnel, that catches all the splash from the drain plug and filter, and directs it to my drain pan. I just roll it up in a ball when I'm done.
Contrary to the claims here, I have found that many, possibly most, Ford dealers have no interest in working on a Class A, Many other garages and oil change places don't want to service something they can't fit in their service bays. I've spoken to RV repair places that had comically high quotes for class A engines and generator oil changes. Obviously, DIY is not something everybody is interested in, or capable of. That said, if you're doing the work at home, don't hesitate to do it on the road. I've saved thousands, know that the work is done correctly, and saved dozens of hours of time, not waiting around for somebody else to do the work.
