Dale_Traveling
Jul 01, 2018Explorer II
99 44/100 of the neighborhood Ford dealers won't touch an RV. You're either too big to fit thru the door or too heavy for the lift. Many no longer have individual bay doors which makes for a very difficult maneuvering prospect to get an RV into a bay. Commercial truck service center are you best option but always call ahead just to be sure they can do the work and can get you in within your travel schedule.
Mobile mechs are also a good resource but you'll need to check with the campground, if you're in one, and need the work done. Many have a no powertrain work rule. Suspect they are concerned with lubricate spills.
The third unmentioned option is to pull a sample of the engine oil at 3/4 of mileage you normally change the oil and send it out to be analysed for extended usage. Might cost around $50 or so and they will email you the results.
