noleakman
Oct 02, 2014Explorer
Oil Change
I have an 06 W22 Chassis WorkHorse! How do I turn off the change oil message on the dash???
ArchHoagland wrote:harold1946 wrote:
Once reset it will give the the change oil message again in 3000 miles.
I'm not too sure about that. A lady engineer at GM developed a way to monitor all the engine parameters and the change oil message will come on based on your driving.
For example, if your engine is running a lot by idling it will require oil changes at less mileage whereas if you are out on the freeway all the time it will go further before a need to change.
I have seen mine go over 5,000 miles before the change oil message, although I don't use that message for my change interval. I'm pretty much in the 3,000 to 4,000 area.
