rfloyd99's avatar
rfloyd99
Oil Change - synthetic oil
I tow a 5,600 lb (loaded wt) TT with my Ram 1500 5.6L gasoline truck. I also have a few hundred lbs in the truck, but all in all I'm well within the towing capacity of the truck.
I had to put a new (rebuilt) engine in it last year. That engine has 11,000 miles on it.
I changed the oil to synthetic right before we left on a 10,000 mile trip. We've driven 6,000 miles so far, of which probably 4,000 have been pulling the TT. I travel about 60MPH, which results in RPMs of 1,500 to about 2,200 most of the time, with the higher number being pretty common. Obviously, higher RPMs happen in the mountains. We are in the West, BTW.
Recommendation for synthetic oil is to change it after 10-15,000 miles, but I'm sure that supposes unloaded passenger car use.
My question: given that I've pulled the load 4K miles, plus 2K unloaded, when should I change this oil?
Thanks!
