I have an 06 Workhorse 8.1 I have been running 5 30 Valvoline I have 55.000 miles now and was wondering If I should change to 10 30 or go to Mobil 1 or just stay with what I have been doing ! I live ...
The only reason to use full synthetic oil is to extend oil change intervals by having samples analyzed at regular intervals. The cost of synthetic oil doesn't make sense to run it and drain it at normal intervals. The only advantage of synthetic over regular oil is less dirt retention and a wider temperature profile. If you drain at normal schedule or don;t have an excessive temperature problem, no need for high price oil. Its a waste of money.
