Campinghoss
Jan 12, 2018Explorer II
rgatijnet1 wrote:jplante4 wrote:
We had a guy in the shop last week during the cold snap here. Cheaped out on chassis Mx for a couple of years. Just changed the oil and filter himself. One of his fuel filters (the one that is hard to reach) was totally plugged with gelled fuel and algae. Stored the coach with 1/8 tank, then started it up to head for FL. Made it about 15 miles before the engine started bucking.
He was in the shop for 6 hours at $140 an hour, plus 2 fuel filters, an air filter and 32 quarts of Rotella and an oil filter. Like the old commercial says; pay me now or pay me later.
If you're going to do your own maintenance, make sure you do all of it.
I agree completely. To add to this,if you are looking to buy a coach from someone that does their own maintenance, make sure that you have it inspected first by a QUALIFIED mechanic, just to make sure that everything has been done, and done correctly.
This may save you a $10,000 bill that I received after a seller left something loose. I made it 260 miles before the problem showed up.
I worked on my own airplanes and if you do your own maintenance on your RV, do it like your life depends on it
I agree totally. A few years back after Coach Care serviced my dp and I had returned home, I brought it over to the garage to pack for an upcoming trip. I noticed it was down on the left rear drastically. After looking it over I found a clamp has slipped off the linkage to the air bag and the bag was not inflating. I raised the rear with the hyd jacks and place 4x4's along the length of the trailing arms. I then lowered till it was resting on the 4x4's. I could barely get enough of my body to the linkage to slip it back together an then put a new clamp on. I called Coach Care and because they felt they had missed it during the service they asked me to bring it back to them. They readjusted the ride heights and put all new clamps on and did not charge me a cent. It pays to have a relationship with good company in my honest opinion.
