Executive45
Jan 12, 2018Explorer III
$300 @ Speedco. Includes filters, oil and fuel, lube and radiator check... as you can see from the above posts, though, each one seems to differ in what maintenance you are doing. Some engines require 15qts/oil, some 28. Mine takes 32. It's worth it to me to let someone else do the work. Draining 32 qts of oil means I'd have to drain it probably 8 times to complete it, move those 32 qts 32 old milk jugs, then cart them to the recycle center. Not really time nor labor efficient. I'd rather play golf, cards, play on the computer or take a nap, which I can do while they're changing my oil...:).....Dennis
