Hello I have a2018 fleetwood bounder on a ford chassis the last time I did the oil ,a few years ago the oil came out on the cross member and ran all over the place and made a mess. Is there a tri...
An oil change every couple of years goes against "my" grain but if removing the drain plug does not allow a clear drop to an oil pan or similar then the Fumoto plug is awesome. My generator has that problem and it was solved with the Fumoto.
