Sir_TravellerExplorerApr 15, 2021oil leakHello Everyone… I have a 2003 Ford F-53 RV Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as...Show More
John_WayneExplorer IIApr 15, 2021Engine oil does not flow through the AC compressor so if it is leaking from the compressor it is fluid used for the AC.
Related ContentNautilus P1 has leaking connectionsoil leakOil filter leakingOil change service??? Mercedes-Benz sprinter.cat c7 oil leak
