Sir_TravellerExplorerApr 15, 2021oil leakHello Everyone… I have a 2003 Ford F-53 RV Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as...Show More
CA_TravelerExplorer IIIApr 15, 2021A/C compressors do contain some oil, but make sure the leak isn't above the pully. Are you sure you didn't spill some oil during the oil change?The belt to the right appears dry which might suggest the leak occurred since the engine was last run because the belt on the compressor is wet.
Related ContentNautilus P1 has leaking connectionsoil leakOil filter leakingOil change service??? Mercedes-Benz sprinter.cat c7 oil leak
