Hello Everyone… I have a 2003 Ford F-53 RV Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as...
Also get a spray can of brake clean and spray off the ac clutch face and plate. Making sure to get the spray into the clearance area of where the clutch plate pulls against and engages. You want it free of oil.
