Hello Everyone… I have a 2003 Ford F-53 RV Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as...
Another suggestion to locate the oil leak is to find a shop or purchase a uv light kit that will allow you to add a dye into any of the oil bearing systems and leaking oil will efflouresce when a black light is shined on it.
